2005 camry a/c problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-02-2009, 06:18 PM   #1 (permalink)
View t&t tech's Photo Gallery
here's the problem, the a/c only circulates cool air when the temperature setting is at cold max, an increase in the temp by even poin five of a degree immediately brings hot air into the cabin, any thoughts, solutions suggestions would be most welcome, thanks in advance to anyone who takes the time to read and offer any help.
t&t tech is offline   Reply With Quote
Old 04-10-2009, 02:35 PM   #2 (permalink)
not even one reply after so long, wow,
Old 04-15-2009, 03:53 PM   #3 (permalink)
2004 Camry LE
somick's Avatar
Gameroom cash: $102015
View somick's Photo Gallery
Free bump
2004 Toyota Camry LE
1999 Honda Accord LX
1992 Subaru Loyale
2010 Subaru Forester
somick is offline   Reply With Quote
Old 04-16-2009, 04:17 AM   #4 (permalink)
View colbert's Photo Gallery
Was what came out smoke or vapour....Sounds as if you may have been using it on auto and if so just have alook at the LED on the selction button....is it flashing out a code or is it a steady light?....It could be the expansion valve or it may be the electronic control unit....If you have a code that's showing....count the number of flashes it gives....thats the fault code number....Get that info first, so that we can go on from there....
Interested in buying your auto parts.Get information on TheAutoPartsShop.com
Toyota Camry Parts
Toyota Camry Brake Pad
colbert is offline   Reply With Quote
Old 05-15-2009, 08:20 PM   #5 (permalink)
anyways, don't wanna sound harsh but this fourum sucks, the problem was as simple as the tubing for the airflow sensor, it came loose a little, preventing air from circulating over the sensor, causing the hot air, thanks for tryng anyways guys.
Old 05-18-2009, 12:08 PM   #6 (permalink)
2004 Camry LE
somick's Avatar
This might be my own attitude but I usually try to find the problem myself before crying for help.......
Glad you found your problem!
Sam
1992 Subaru Loyale
