Battery or Alternator? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2009, 10:15 AM   #1 (permalink)
View pbinder's Photo Gallery
Exclamation Battery or Alternator?
I have a 2005 Camry LE V4. I recently got into my car and went to start it but it wouldn't turn over, no power.
After taking whatever power from the battery to try and crank it, some of my dash lights came back on.
Tried to crank it again and nothing.
I had a friend come out and he gave me a jump. We kept the cars hooked up for a minute or two while my car was running and then disconnected.
On my way home, when I hit the breaks, I could see my headlights dim a tad bit. When I put on my brights my whole dash went off for a quick second.
When I got home, after a 7-10 minute drive, the car was still basically dead. It would not start again.
SO. Does this sound like a battery that is completely caput (I'm getting a new battery no matter what) or does it also sound like an alternator problem as well as the now dead battery?
I have never replaced the battery since buying the car new in February 2005.
Thanks for any help.
pbinder is offline   Reply With Quote
Old 03-04-2009, 11:01 AM   #2 (permalink)
View bullisbm's Photo Gallery
It sounds like a battery issue to me, but why don't you just go to a auto parts place and have them both tested? That way your not guessing.
bullisbm is offline   Reply With Quote
Old 03-04-2009, 11:09 AM   #3 (permalink)
Gameroom cash: $304355
First of all you have an I4 engine, not a V4. It is also advisable to list the mileage on the car when asking for advice.
Your problem could be either the battery, the alternator itself, a loose alternator belt or simply loose or corroded battery posts/cable connections. If you don't feel comfortable checking thses things yourself, I suggest calling around to auto parts stores in your area and asking if they do free battery and alternator checks with these items still on the car. When you find one that offers this free service (many do) have the car jump started again and drive it over to that parts store. Do not shut off the car. Go in and ask them to test these items for you. Incidently, you can usually just do a visual inspection of the battery posts/cable connections looking for built up corrosion. Also, it's a bit early (4 years old), but not impossible for your battery to be going, in my opinion.
Mike
Old 03-09-2009, 02:57 PM   #4 (permalink)
2007XLE
View 07camryxle13501's Photo Gallery
Alternator..... jump the the car and soon as it truns on unhook the jumpers and take out the Battery if the car stays on its your Battery if it truns off its you Alternator
07camryxle13501 is offline   Reply With Quote
Old 03-10-2009, 12:22 PM   #5 (permalink)
"and take out the Battery"
Do not do this with the car running. This is no longer a safe thing to do. It did this myself many years ago, but it should not be attempted on today's modern cars. The voltage spikes created by disconnecting the battery on a running car could ruin some of the sophiscated electronics on today's cars.
Mike
Old 03-26-2009, 02:59 AM   #6 (permalink)
icqboy51's Avatar
View icqboy51's Photo Gallery
the OEM battery only lasted 4 years?
cause my 2003 OEM battery is still going strong.
[Gen5 - DIY] Footwell CCFL
http://www.toyotanation.com/forum/signaturepics/sigpic169867_1.gif
icqboy51 is offline   Reply With Quote
Old 03-26-2009, 11:01 AM   #7 (permalink)
View titoisme's Photo Gallery
sounds like alternater to me, i had the same problem, even changed batteries and same problem kept coming up...after i changed the alt., it's run fine -- also, if the battery light comes on, it's an alt problem, not actually battery
titoisme is offline   Reply With Quote
