accel squat - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2004, 08:27 PM   #1 (permalink)
View high c's Photo Gallery
accel squat
ok heres the deal, i put a turbo on my car and it runns realy good but were i run into the prob is when i hit boost the tires brake free and i cant keep grip. dose any one make a stiffer spring for the back to keep the accel squat in check?
"I live my life a 1/4 mile at a time" or "burn rubber not your soul" eather way you sound like a retard
high c is offline   Reply With Quote
Old 01-21-2004, 08:29 PM   #2 (permalink)
www.whomikejones.com
View dan99solara's Photo Gallery
what kind of car do you have?
dan99solara is offline   Reply With Quote
Old 01-21-2004, 08:30 PM   #3 (permalink)
Beams SV21
da_horse's Avatar
View da_horse's Photo Gallery
off topic, but would you have any pics of your car? and what gen etc is it? good to see another turbo camry around here....
all the best
Huy
Huy
1989 BEAMS 3S-GE SV21 Camry
2003 ST246 Caldina GT-Four N
da_horse is offline   Reply With Quote
Old 01-22-2004, 12:54 AM   #4 (permalink)
getn groceries in style
jwa276's Avatar
View jwa276's Photo Gallery
the best solution to your tire spin problem would be a limited slip differential, to put even amounts of power to both tires. as far as suspension goes, you could use some whiteline springs. eibach and intrax are also good. also if you replace the springs, struts would be a very good idea as well. it would near eliminate the take-off type feel from rearing back when you floor it. the best performance solution is probably a coilover setup.
jon
'92 Camry SE V6 5spd
jwa276 is offline   Reply With Quote
Old 01-22-2004, 02:16 AM   #5 (permalink)
Man on a mission...
View SKYravefever's Photo Gallery
I hate to sound cynical, but how did you manage to turbo your car, and not know about the possibility of an LSD. (based upon you not mentioning anything about it).
Time is never wasted when you're wasted all the time.
SKYravefever is offline   Reply With Quote
Old 01-22-2004, 02:20 AM   #6 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
hummm how about you learn how to drive and not spin tires off the launch,
that's pretty much the basis of racing
-Nick
Nick is offline   Reply With Quote
Old 01-22-2004, 07:30 AM   #7 (permalink)
not actual size
brink's Avatar
View brink's Photo Gallery
LSD will probably help some. Don't just think about the back being stiffer... having more resistance in your front will help as well. Rear to prevent squatting, front to prevent hopping. Grippier tires for sure will help, but if your location "ME" is for Maine, you might not want to do that during the winter
-- Jonathan W.
http://fleshy.org.nz/
brink is offline   Reply With Quote
Old 01-22-2004, 07:35 AM   #8 (permalink)
hazrd's Avatar
View hazrd's Photo Gallery
get ur springs and struts replaced for a start.... i found i have reduced squatting when i shoot off the line.. but as he wise oldman said ... ... u should learn to reduce the spin off the line which will result in a better takeoff leaving the big cubic inches behind!
HazRD
hazrd is offline   Reply With Quote
Old 01-22-2004, 08:13 AM   #9 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
Getting wider tires helps too. I went from 185/70's to 205/60's on my 2nd gen and that help out tremendasly on traction. Also when you are going off the line you can't just floor it you have to baby it off the line so you wont get spinning and then floor it. Anyone that is a good driver can tell you that it isn't just about going wide open as soon as the light turns green. There is actual skill involved.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
Old 01-22-2004, 11:40 AM   #10 (permalink)
it dosent really light'em up off the line when i come in to boost thats when the tires brake free, and as for the tranes its an automatic, gen 2
oh and "hummm how about you learn how to drive and not spin tires off the launch, that's pretty much the basis of racing" why dont you make a car that can spin them off the line, befor you tell others how to drive
Old 01-22-2004, 02:18 PM   #11 (permalink)
SCCA Tech Services
You know why do you ask for help if you are just going to trash people. If you just trash the people that try to help you then stop asking the questions. Also The only car I have owned that I couldn't spin the tires is my 89 camry. My 88 camry can spin the tires very easily and if you don't beleive me then how about your sorry ass come out here and I Will race you and I will still beat you with a car that is NA and an auto. Also I have owned a 3rd gen celica that I could easily spin the tires and my 81 celica that I have now I could spin the tires and that was with a clutch that could only grip in 1st and 2nd so I know how to freaking drive. Just because you can spin the tires doesn't mean crap it is having the power to spin them and not spinning them is the skill and obviously you don't have any skill.
Brian Harmer
Old 01-22-2004, 04:41 PM   #12 (permalink)
lol, wow so this is what happens when you are better then some one...like me im better then oldman, so insteed of him fighting his own fights he has some one ells do it.....big man. i ask the Q and then i get trashed by oldman so WTF is that all about?
Old 01-22-2004, 04:56 PM   #13 (permalink)
Nick's Avatar
my v6 can spin off the launch, anyways, sorry about that, i guess it came out a bit rude
but seriously, you just have to know where that threshold is and don't cross it
wider, grippier tires, polyeurathane engine mounts, i guess you could put v6 springs up front, with really stiff struts
-Nick
Old 01-22-2004, 05:09 PM   #14 (permalink)
Nick's Avatar
you said it yourself....
-Nick
Old 01-22-2004, 05:38 PM   #15 (permalink)
i did didnt i but even beeter at 30 mph it dose....
