Timing belt replacement - need suggestions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2004, 09:22 PM   #1 (permalink)
View cdavies's Photo Gallery
My wifes '93 Camry 4 cyl (5S-FE) with 168K miles just died.
After a quick diagnosis, I determined that the timing belt had let loose. I have removed the top cover and am having some difficulty removing the harmonic balancer from the crank. I have tried an air impact wrench to no avail. Anyone have another suggestion? I am going to try to get a large breaker bar on it but was wondering hoe I could keep the engine from turning.
Also since I am into it this far and considering the mileage and the fact that I plan to keep the car for a while longer, what other things should I consider replacing. As far as I know the water pump has never been replaced.
Thanks for the assistance.
Charlie
cdavies is offline   Reply With Quote
Old 01-21-2004, 10:34 PM   #2 (permalink)
View toysarefun's Photo Gallery
Here is one site I know of offhand with some kind of directions..
http://yotarepair.com/5S-FEtimingbelt.html
The crank is always a bear, soak it. With manual tranny you can put it in high gear and that helps. Keep asking around. Some people weld together their own special tools for things like this.
toysarefun is offline   Reply With Quote
Old 01-22-2004, 11:56 AM   #3 (permalink)
View Nico's Photo Gallery
I wouldn't replace the water pump yet. If it still runs keep it at least untill next time you change the timing belt.
Nico
Nico is offline   Reply With Quote
