Foglights Malfunction - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2004, 04:27 AM   #1 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
View terrynham's Photo Gallery
Hi,
I put in a set of aftermarket Foglights onto my 1994 Camry. I got the auto electrician to link the lights to a switch and also through the parking lights (for the auto-off function).
However, the other day the foglights just stayed on?......the switch was off and the parking lights were off too!.......this has only happened twice, once in April 2003 and then the other day......
Would anyone know what could be going wrong?
Thank you.
terrynham is offline   Reply With Quote
Old 01-23-2004, 07:11 AM   #2 (permalink)
FloridaPino
eviltwin67's Avatar
View eviltwin67's Photo Gallery
Did he use a relay or did he just wire them straight to the parking lights? If it is relayed, it sounds like the relay may be faulty.
96 V6
Amsoil foam filter
Upgraded headlight Harness w/ Sylvania Cool Blue
APS 996A Remote Start Alarm
eviltwin67 is offline   Reply With Quote
Old 01-23-2004, 09:00 AM   #3 (permalink)
Prepare tortilla chips.
Daffunda's Avatar
View Daffunda's Photo Gallery
Most likely the relay. Fog lights are not that hard to install yourself, you know.
Daffunda is offline   Reply With Quote
Old 01-23-2004, 09:56 AM   #4 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
sometimes my 25$ foglights do stay on, but i usually notice and pull the relay,
i think it gets too hot and just won't shut off
-Nick
Nick is offline   Reply With Quote
Old 01-23-2004, 06:12 PM   #5 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
yeah, the electrician did put a relay in. But I forgot to mention that the first time this happened (April 2003) the foglights were wired through only one switch.....and after this problem happened I told the electrician to wire them in with the parking lights aswell so the foglights go through 2 switches.
also what was strange is when this happened the second time the other day, they only turned off when I poked at the wires behind one of the lights?
any ideas on what is going on?
~ Terry
Old 01-23-2004, 07:02 PM   #6 (permalink)
Daffunda's Avatar
I think you should rewire it yourself. The guy who did it probably didn't know what he was doing.
Old 01-23-2004, 10:09 PM   #7 (permalink)
FloridaPino
eviltwin67's Avatar
Here is the correct way to wire your lights: http://danielsternlighting.com/tech/relays/relays.html
96 V6
Amsoil foam filter
