stearing wheel vibration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-11-2009, 07:55 PM   #1 (permalink)
View olddude7's Photo Gallery
USA stearing wheel vibration
I have a 1996 camery the problem is when i stop the car and leave it i gear i get a bad vibration in the stearing wheel.When i go again it stops.I have changed the trans and motor mounts.
olddude7 is offline   Reply With Quote
Old 04-12-2009, 12:25 PM   #2 (permalink)
Gameroom cash: $304355
If you have the 4 cylinder 2.2 liter 5SFE engine, some vibration at idle is normal. Some people on this forum have had some success at reducing the vibration by switching the dogbone motor mount to the one used on the generation 4 (1997-2001) Camry. Do a search on this forum for "idle vibration" and you should find the thread on that.
Mike
Old 04-13-2009, 09:56 AM   #3 (permalink)
View Judge2's Photo Gallery
My guess is that one of your rotors is warped, because it is occuring when you are stopping the car. Do you feel any pulsation sensation in the brake pedal?
Judge2 is offline   Reply With Quote
Old 04-13-2009, 04:54 PM   #4 (permalink)
View Brakemotive's Photo Gallery
You would not feel a vibration when the car is at a dead stop with a warped rotor only when slowing down. Sounds to me as another member has said to be just vibration through the engine, it may not be a bad mount it might just be running rough and sputtering a bit at idle. I can almost tell you for sure though that looking at the brakes for this issue is a waste of time.
Brakemotive is offline   Reply With Quote
