2006 Camry Timing Belt Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-12-2009, 07:58 AM   #1 (permalink)
View Geffen's Photo Gallery
I recently received a service reminder to have my 60,000 service performed on my 2006 Camry LE 4cyl would I need to have my timing belt replaced? if so how expensive of a cost to have it replaced at the dealership?
Geffen is offline   Reply With Quote
Old 04-13-2009, 04:14 PM   #2 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
The 2.4L four-cylinder engine in your Camry has a timing chain, not a timing belt. The chain is supposed to last the life of the car. Your reminder may be a generic one, or it may be referring to the serpentine belt.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 04-13-2009, 08:11 PM   #3 (permalink)
Thanks for the reply, does the timing chain ever need to be adjusted?
Old 04-17-2009, 03:32 PM   #4 (permalink)
Unless something happens, no, the timing chain shouldn't ever need to be adjusted. At 60K miles you might want to consider a drain/refill of your transmission fluid if you haven't done it already. I've got a 2005 and I did mine at 3yr/25K miles and again at 4yr/34K miles. That might be considered excessive to some but it only takes 15 minutes including prep and clean up so I don't mind.
moving forward
