engine mounts.. how many are there? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-25-2004, 07:25 PM   #1 (permalink)
ubongen's Avatar
View ubongen's Photo Gallery
I need to replace my motor mounts on my 89 camry. I looked through my repair manual on only seen that there's 2 motor mounts. one on the side and the other underneath. is that correct or are there more mounts?
thanx....paul
ubongen is offline   Reply With Quote
Old 01-25-2004, 08:24 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Theres more then 2 mounts.
Front mount & rear mount. Both bolt to the tranny.
Left mount: bolts to the block.
Right mount: bolts to the top of the tranny.
And another mount on the back of the block. Bolts to the block and crossmember.
"Skoolin' the unlearned!"
Old 01-25-2004, 09:20 PM   #3 (permalink)
ubongen's Avatar
DAMN..!!! that's a whole lot of mounts!
man....where can I get all those mounts without breakin' my bank book? sheesh..and I thought gettin' my 89 Cam with 167k for $1000 was a good deal.
freakin' A!!!!
thanx for the info... paul
Old 01-26-2004, 02:27 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
I would check out the mounts first before you go replacing them for the hell of it.
The ones that usually go bad are the front and rear mount.
