sup guys i got a 95 camry 4 cyl. recently ive noticed some bluish/white smoke coming out the muffler when i start the car. happens when the engine is cold. i read somewhere that it could be the valve seals? any ideas?
How does it look when the car is warmed up though?
2003 BMW 540i 6-spd
2008 Toyota Rav4 Limited V6
2005 Mazda 3 Sport GT 5-spd (just sold)
1995 Nissan Maxima SE 5-spd... Best ET: 13.8... Best trap: 99mph (Gone)
1993 Toyota Camry LE (Gone)
um ok so what/where are the valve seals? i got no clue lol. im about due for an oil change, so if its burning oil how do i fix this? is replacing the valve seals expensive? when the engine is warm and i start it there is no blue smoke, only when the engine is cold. right when i start the car it farts out a puff of blue smoke then goes away.
<font size=-1>[ This Message was edited by: Sub Zero on 2002-03-16 03:40 ]</font>
for valve seals you'll need to remove the head... its an expensive task just for seals. how many miles do you have on your car? the seals shouldnt go out that easy... hmm. seals arent that expensive though, its just the process of taking off the head and putting it back on... remember when you take off the head you'll need to also reaplace all the gaskets and headbolts to be safe.
On 2002-03-16 13:36, Sub Zero wrote:
i have about 117k on it. can u estimate how much the cost would be for all that? if i dont get it fixed would it damage the engine?
Yes it is bad for your engine and also for the environment.
2003 BMW 540i 6-spd
all that oil burning over time will coat the inside of your catalytic convertor and cause the exhaust not to be catalysed properly and it will come back into engine and cause the car to run a littler hotter and rougher. The porcelain in the catalytic convertor is very sensitive and will not like being coated by all that carbon!
I have the same problem and used CD2 to stop smoke by putting it in when I changed my oil and it actually worked...Would it screw up the catalytic converter if there wasn't one
you can reach me on AIM @ budking52r
1996 Camry 2.2L
Waiting until I graduate to buy a 2005 Toyota Tundra V8!
CD2 is an oil additive that helps out your rings and such. Its not exactly a cure but when used regularly it can prevent/decrease oil burning.
I used it myself on the old galant I had. It would smoke real bad at startup before I used CD2. It didnt completely go away, but it it got it down to just a little puff.
