Originally Posted by philipwk
Is there free information of how to replace the front Mcphearson strut top mounts?
1998 TOYOTA CAMRY 4 Cylinders 02164 G 2.2L EFI DOHC
On the '97 (which I think is very close to the '98), you have to remove the strut and spring ass'y from the car(2 bolts on the bottom-to the steering knuckle + 3 bolts on top-in eng. bay, DO NOT remove the center nut!!!).
Once removed, using a coil spring compressor, compress the spring and remove the nut attaching the strut to the top mount.
HTH
JerryR
