New Style Oil Filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-20-2009, 09:50 AM   #1 (permalink)
View siennavan's Photo Gallery
My 2010 Camry has the new style oil filter with the filter element being the only part to replace. I would appreciate it if someone would tell me where I might get the instructions on how to accomplish this task. I would also like to know if it requires any special tools. Thanks for your responses.
siennavan is offline   Reply With Quote
Old 05-20-2009, 10:48 AM   #2 (permalink)
2004 Camry LE
somick's Avatar
Gameroom cash: $102015
View somick's Photo Gallery
The only place I know for Camry manuals is:
www.camrystuff.com
Try it,
Sam
2004 Toyota Camry LE
1999 Honda Accord LX
1992 Subaru Loyale
2010 Subaru Forester
somick is offline   Reply With Quote
Old 05-20-2009, 11:40 AM   #3 (permalink)
Gameroom cash: $202300
View zppeacock's Photo Gallery
You have the new Cartridge style filter. Its pretty simple, If you get the toyota filter it will show you on the box how to change it. You do need a toyota filter cup.
zppeacock is offline   Reply With Quote
Old 05-22-2009, 08:28 AM   #4 (permalink)
I did have a quick look on a box containing the filter in the parts department. There is a plastic plug that is inserted in the hole after removing an outer plug to allow the oil to drain. It looked like a hose can, or should be attached to the plastic plug to direct the oil flow. Is this necessary? Does removing this plastic drain plug shut off the drain oil so that a normal filter socket can be used without any remaining oil draining into the filter socket?
