Just so you know, if your temp shows too low or too high, it may also be your thermostat. The thermostat housing is located on the bottom left side of the motor (in the 5SFE) and is the big tube that the bottom radiator hose connects to. If you are running too cold, it is because your thermostat isn't staying open the way it should be. This will cause the coolant in the radiator to get really cold and dump into the engine. If you are running too hot, it may be because your thermostat is just not opening.
All motor. Leave the body kits off and make the car move fast, corner tight, stop fast and always blueprint your engine work.
