Does this save gas? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-04-2009, 08:58 AM   #1 (permalink)
stanno's Avatar
Gameroom cash: $103635
View stanno's Photo Gallery
Does this save gas?
Out of all the little things i do to conserve gas in my camry, there's one i'm eager to kno if it works... that is, putting the transmission in N while i'm at a light or come to a stop longer than 5 secs . am i saving any gas there or am i just wearing my transmission down faster by doing that ...?
- stanno
stanno is offline   Reply With Quote
Old 06-04-2009, 02:03 PM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Yes it does reduce fuel consumed.
Shifting from Neutral to Drive should not wear out the transmission clutches by an appreciable amount. Engine mounts will get stress (compression and tension) relief as well.
This will remove load to engine and then EFI controller can reduce fuel used and advance ignition timing to keep engine running without stalling.
Do you run AC?
Every time the engine is loaded ie AC, power steering, lamps, etc. the engine control will 'idle up' to provide enough power from engine to run these ancillary systems.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 06-04-2009, 02:32 PM   #3 (permalink)
stanno's Avatar
Do you run AC?
I'm real happy to know it does. my car is equipped with a/c but i don't use it if i'm trying to conserve petrol.
Old 06-07-2009, 09:40 PM   #4 (permalink)
viktord1's Avatar
View viktord1's Photo Gallery
Some say that at around 65mph it's more efficient to use your A/C than to roll down the windows.
My cousins Subaru Outback 2.5i got 33mpg highway with the A/C on, and on the way back on the same road we got 33mpg with the windows and sunroof rolled down
Vik
Gen2 FTMFW
viktord1 is offline   Reply With Quote
Old 06-07-2009, 11:15 PM   #5 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
Gameroom cash: $100200
View JCamry94's Photo Gallery
3rd Generation
^ well la-tee-da
It definitely does a small amount. I try to coast when I'm short gas as well.
I've heard that somewhere between 2 - 3k rpm's lies the most efficient spot for acceleration
ACCIDENT...
Help me bring 'er back to life!!!
BUY MY STUFF: http://www.toyotanation.com/forum/66...e-all-obo.html
Thanks
JCamry94 is offline   Reply With Quote
Old 06-08-2009, 01:47 PM   #6 (permalink)
Gameroom cash: $304355
I would just leave the car in drive. The tiny amount you may be saving on fuel is offset by the wear you are putting on the transmission and the engine mounts, IMHO. If this was really an effective way to save on fuel, all the OEM car manufacturers would be recommending it.
Mike
Old 06-08-2009, 09:34 PM   #7 (permalink)
Deadly Sushi's Avatar
View Deadly Sushi's Photo Gallery
Dear Lord! Do NOT keep putting it in neutral at lights!!! You are wearing MANY components out needlessly. It MIGHT...... might save you a few drops of fuel but no WAY is it worth it.
Try using acetone in your fuel. I know we have a write-up about it somewhere.
1992 Camry I-4 with 145K miles
Deadly Sushi is offline   Reply With Quote
Old 06-08-2009, 10:51 PM   #8 (permalink)
SaganGanthering
View SaganGathering's Photo Gallery
(in cars using electronic fuel injection) when turning off the engine at stops of 30 secs or more. (I've heard as little as 10 secs from other, less famous sources)
I easily found one of their pages on the topic:
Source: http://www.ucsusa.org/publications/g...u-nowhere.html
This was a slightly-related forward-looking brief on saving fuel: http://www.ucsusa.org/clean_vehicles...to-reduce.html
SaganGathering is offline   Reply With Quote
Old 06-09-2009, 09:37 AM   #9 (permalink)
stanno's Avatar
okay, some folk say it wont cause any significant wear on my transmission, and others say it will. is it yay or nay on goin neutral at stops ... cuz if it does cause damage, it's really not worth it... and i really dont want to have to replace this tranny any time soon
Old 06-09-2009, 08:48 PM   #10 (permalink)
I wouldnt risk it. ESPECIALLY for such a tiny drop of fuel.
Old 06-10-2009, 08:46 AM   #11 (permalink)
View Lightning Blue's Photo Gallery
I wouldn't do it either, plus, it can be a safety risk.
2001 Camry LE - I4 - 138,xxx miles
2005 Neon SXT - 47,xxx miles
Lightning Blue is offline   Reply With Quote
Old 06-10-2009, 09:51 AM   #12 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
i always shift my transmission to N and coast to a stop sign and at traffic light stop, but mine is a manual transmission, my brother always leaving it in gear and holding down the clutch while stop, and i thought that would have more wear to the clutch disc.
http://mysite.verizon.net/vaio338168/avator.jpg
2002 2AZ-FE, LE Phantom Grey Pearl, Retrofitted with LS430 Projectors on SE Headlights. Aftermarket Foglight
bronzemaxell is offline   Reply With Quote
Old 06-10-2009, 01:18 PM   #13 (permalink)
stanno's Avatar
in your case it would be different, more or less, a manual transmission was designed to be engaged and disengaged frequently from time to time, whereas a auto, was made to be put in "Drive" and go. more precisely i think your brother sitting on the clutch at a stop would put excessive wear on the pressure plate more than anything else. better to neutral in the case of a manual imho ...
Old 06-10-2009, 05:48 PM   #14 (permalink)
viktord1's Avatar
dont shift to neutral while you are trying to stop the car. that way you are not using the engine's breaking effect and your brakes will wear out faster.
Vik
Gen2 FTMFW
Old 06-10-2009, 09:42 PM   #15 (permalink)
i've heard about other people saying speed and gear match shifting while decelerating, but i rather shift to N, replace brake pad is much easier than changing clutch disc and pressure plate.
and i had very bad experience not shifting to N trying to stop the car, one time i was driving on two lanes shopping mall traffic going at 10 to 15 miles per hour, the guy next to me decided to shift over to my lane without looking, signaling, maybe blind spot, within a split second, i stepped on my brake padle so hard to avoid the collision, one hand honk horn, one hand on steering wheel, no hand to shift to N, no time to step on clutch pedal, and my speed went to 0mph, so i brake while transmission in still in gear, and the engine stalled, lost all power assist, luckily i got away without any scratch, restarted my car and kept going.
