Originally posted by LWF
here is the JDM OEM headlite
^^^^ That's the solution right there if money doesn't matter, those are diamond clear JDM headlamps that will directly fit your '97 Camry.
As mentioned, I recieved a quote for $430 a pair......then again, you'd probably be the only guy with them around so it may be worth it
Keep in mind that if you do HID, that the JDM lamps are designed to light up the left side of the road because of righthand driving..........so you do run the risk of blinding oncoming drivers, but you could always add a strip of sheet metal inside to block that light.
