Center Console Shifter Light Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2004, 12:54 AM   #1 (permalink)
View tdsmith6's Photo Gallery
I have a 1998 Toyota Camry XE and recently the lamp that illuminates the gear shift indicator on the Center Console has quit working/burned out. I would like to see if anyone knows how to remove and replace. Any help wpuld greatly be appreciated.
Thanks,
TDSMITH6
Chandler, AZ
tdsmith6 is offline   Reply With Quote
Old 02-07-2004, 01:23 AM   #2 (permalink)
View TRDiCamry's Photo Gallery
changing the bulb is very very simple as it simply twists off and the new buld will twist back on.
you will however, need to pull out the centre console and remove the gauge cluster to get to it
TRDiCamry is offline   Reply With Quote
Old 02-07-2004, 09:44 PM   #3 (permalink)
FloridaPino
eviltwin67's Avatar
View eviltwin67's Photo Gallery
I just changed out the bulb on my 96 to a red LED at the same time that I "shortened" my A/T shift lever and changed out the shift knob. I already had the factory shift knob off so it was easy to get the cover with the gear indicators off. The bulb in mine was a 194, but I'm not sure if it will be the same for a 98. One you get that off, it's a pretty straight forward remove and replace.
96 V6
Amsoil foam filter
Upgraded headlight Harness w/ Sylvania Cool Blue
APS 996A Remote Start Alarm
eviltwin67 is offline   Reply With Quote
