Remove 3s-fe valve cover - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2004, 03:57 AM   #1 (permalink)
View jay_wang2000's Photo Gallery
Smile Remove 3s-fe valve cover
Recently, I saw oil leaking from valve cover gasket. I plan to install new gasket. My car is camry w 3s-fe engine. But I do not see any bolt on the valve cover. How to remove this cover ? It is appreciated for any help.
Jay
jay_wang2000 is offline   Reply With Quote
Old 02-07-2004, 04:37 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Pull the sparkplug wires and you'll see 4 nuts holding down the valve cover.
You need a 30mm socket or a big adjustable wrench.
"Skoolin' the unlearned!"
Old 02-07-2004, 03:15 PM   #3 (permalink)
View DIRTBIKEZ's Photo Gallery
Dont forget to use high temp sealant on those eight spots.
'91 Camry DX
2.0L 3SFE Auto
R.I.P.
DIRTBIKEZ is offline   Reply With Quote
Old 02-08-2004, 05:34 PM   #4 (permalink)
Zzzz...Caught ya Sleepin'
View TRDCAMRY's Photo Gallery
Is this the same process for removing the valve cover off of a 5SFE?
TOYOTAS RULE!!!!!!!!!!!
1995 Toyota Camry TRD
http://www.cardomain.com/id/kaystrd
TRDCAMRY is offline   Reply With Quote
Old 02-08-2004, 07:12 PM   #5 (permalink)
Grenaded piston
88 LE's Avatar
Yes.
Old 02-08-2004, 08:58 PM   #6 (permalink)
3rd 5-speed Camry...
87Camry5Speed's Avatar
View 87Camry5Speed's Photo Gallery
Hi-temp sealant? When I had my cover off in a vain attempt to polish it to a shine (aluminum is hard like that!), I replaced the gasket but it has a ridge which matches the groove in the head. I didn't use sealer. Where are these spots to which you refer... btw this was about 20 mos. ago when I had it off and still no leaks...
thanks
'08 Camry LE 5-speed. Traded for an '04 Mustang GT.
87Camry5Speed is offline   Reply With Quote
Old 02-14-2004, 12:02 AM   #7 (permalink)
Where are those eight spots ?
Jay
