Hi all,
first post, I'm hoping for a miracle here.
I got a bit stuck in the snow two days ago and now I've been having nothing but problems with my 89 Camry All Trac A540H Auto Transmission.
With the engine OFF -
On the inside of the car: Shift into N, the car will roll backwards no problem.
In the engine bay: Shift through gears, can see the cable actuating the shift mechanism, no problem, no binding by the looks of it.
With the engine ON -
1) In P - hit the gas, the car tries its best to roll forward
2) In R - hit the gas, the car revs labored and doesn't move
3) In N - hit the gas, it's like I'm in D
4) In D/2/L - hit the gas, it's like normal
In the engine bay: Same as with the engine off, everything looks normal (on the surface).
I have checked the electrical connections to the transmission by just checking to see if all of the connectors are connected properly - I have not tested with a VOM or anything else for diagnostics.
I'm stuck, this is my daily driver and it's basically dead in the water and now I can't move it because I can't back-up out of my driveway...please, any advice would be most appreciated!
Thanks
