Abs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2004, 07:43 PM   #1 (permalink)
View toyotaman's Photo Gallery
Abs
i have the 01 camry ce w/ the 5sfe i got used a while back where whould the abs be under the hood i know what it looks like (i think). i cant find it (if it has abs) i'm no mechanic but i just whated to know if mine had it.
toyotaman is offline   Reply With Quote
Old 02-07-2004, 07:48 PM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
go to an empty snowy parking lot, get a bit of speed (10-15mph) and firmly apply the brakes, (pretty much just floor the brake)
if you feel the pulsation, you got abs
-Nick
Nick is offline   Reply With Quote
Old 02-07-2004, 10:24 PM   #3 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
What if theres no snowy parking lots?
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline   Reply With Quote
Old 02-07-2004, 10:32 PM   #4 (permalink)
Relax, guy!
View Number Eight's Photo Gallery
Regular parking lot. Just get a bit of speed and slam (and hold) the brakes. If you hear a rapid thumping and the car pulses - and you're able to steer the car with the brake pedal all the way down - you have ABS. Just get in a situation where the brakes would normally lock, but do it in a safe area and give yourself some space.
Number Eight is offline   Reply With Quote
Old 02-07-2004, 10:42 PM   #5 (permalink)
View S-FL camry's Photo Gallery
and if u cant steer, well damn... u know u dont got ABS
beee safe
S-FL camry is offline   Reply With Quote
Old 02-07-2004, 11:28 PM   #6 (permalink)
VVT-i Owns's Avatar
View VVT-i Owns's Photo Gallery
look under the hood there is this block thingy with 4 steel lines running to/ from it.
- Vince
VVT-i Owns is offline   Reply With Quote
Old 02-07-2004, 11:31 PM   #7 (permalink)
View oibone781's Photo Gallery
is the abs light suppose to be on all the time? my light has been on for a long time..
oibone781 is offline   Reply With Quote
Old 02-08-2004, 12:15 AM   #8 (permalink)
View kenxle's Photo Gallery
Talking
I do not think 01 CE has abs, even the LE does not has it. Only XLE has it
kenxle is offline   Reply With Quote
Old 02-08-2004, 12:50 AM   #9 (permalink)
Azn
View Azn's Photo Gallery
It all depends on the car package! My 2000 LE has abs
Azn is offline   Reply With Quote
Old 02-08-2004, 11:31 PM   #10 (permalink)
View 00camry's Photo Gallery
you sure the 2000 le has abs? i'm pretty sure my 00 cam has 4 disk brakes.
00camry is offline   Reply With Quote
Old 02-09-2004, 08:31 PM   #11 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
i thought the abs warning light on dash comes on for a few seconds, then off when the ignition key is turn to on position.
if abs light stays on if it is malfunction somewhere.
the abs module normally located on the passenger side, near the coolant reservior, about 6 tiny metal hoses coming out of it,
and if you look at each wheel, there is an abs sensor wire lead to each rotor/axial in addition to the brake wire.
http://mysite.verizon.net/vaio338168/avator.jpg
2002 2AZ-FE, LE Phantom Grey Pearl, Retrofitted with LS430 Projectors on SE Headlights. Aftermarket Foglight
bronzemaxell is offline   Reply With Quote
Old 02-09-2004, 10:25 PM   #12 (permalink)
Azn
Yes 00camry, My Camry does have abs because when I apply the brakes I feel the pulsation where winter when it snows!!!!!!
