Around $200 seems about right to me., but then I'm dealing with Chicago area prices. Most of the time it's not necessary to replace the calipers. They are replaced only if the piston in the caliper is seized (This is different from the caliper not sliding on it's slide pins.), or the caliper is leaking brake fluid form the seal around it's piston. You may need to replace the rotors if they are badly scored and can not be turned (Trued on a brake lathe to remove any grooves and make them perfectly flat again.). That would add about $120 to the job.
It would also be helpful to know what year car you have, what engine is in the car and the current mileage; and if any brake work was previously done, what exactly was replaced at that time and how long ago.
Mike
