Trouble starting after rain HELP - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-08-2004, 11:15 PM   #1 (permalink)
View bradgotti's Photo Gallery
Every damn time it rains my '91 Cam doesn't want to start and then after it starts it runs bad and acts like it wants to stall out and sometimes the engine actually does die if I don't lay on the gas. Anyone else have this problem...Any possible solutions would be greatly appreciated.
'91 Camry 4cyl diesel
bradgotti is offline   Reply With Quote
Old 02-09-2004, 01:58 AM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
you've probably got something cracked in your ignition system, probably the distributor cap, but could also be the wires or the coil
-Nick
Nick is offline   Reply With Quote
Old 02-09-2004, 07:46 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Cracked coil.
"Skoolin' the unlearned!"
Old 02-10-2004, 10:34 AM   #4 (permalink)
Don't wanna sound like an idiot, but I'm kinda new to the Toyota repair world...but where exactly is the coil on a '91 Camry 4cyl.? I checked the cap and wires and they are all good BTW
Old 02-10-2004, 10:39 AM   #5 (permalink)
Nick's Avatar
i don't know for gen 2's but its probably on the driverside inside fender
you can also just follow the center wire of the distributor back to the coil
-Nick
Old 02-10-2004, 02:33 PM   #6 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Found it? Try this!
If you haven't found the culprit yet, raise the hood, and start the engine in a dark place, or at night and look for stray sparks.
It should show you what is cracked and in need of replacement.
I would suggest strained points, like wire/boot junctions. Boot connectors on the coil pack, and any wire guides.
On my 89 cavalier, I sprayed it with grease and that insulated it enough to run.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 02-10-2004, 07:28 PM   #7 (permalink)
Grenaded piston
88 LE's Avatar
Its on the bottom of the distributor.
