OK Everyone -- I'm at my wit's end on this one. Wife is mad at me,
>and no shop has been able to find anything wrong on diagnostics.
>Symptoms: ONLY on hot, humid days, ONLY first one or two startups,
>hesitates, stalls, no power, feels as though timing is WAY off.
>Then clears up. Thought I had the problem fixed two weeks ago when
>I replaced the cap and rotor, but guess only temporaily. After the
>second startup, the car runs like a charm.
>Cap was really bad inside, and rusty (not sure why) and the graphite
>knob in the center wasn't on its spring, but rather pushed all the
>way inside the rotor making the spark jum to the cap. Oxygen sensor
>doesn't even come on unitl reaching a certain tempature right?
>If it was old enough to have a vaccum advance, I'd swear it was the
>problem. But since it has electronic ignition, where do I turn?
>Also could be some kind of "choke" or "cold start valve" -- but I
>haven't found the "hot and humid" start valve to replace!
>the car is a 1990 Toyota
>Camry LE
Thanks for any help you can give!
Dave
