Mixing oils? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-16-2009, 12:40 AM   #1 (permalink)
Deadly Sushi's Avatar
View Deadly Sushi's Photo Gallery
Mixing oils?
OK... 5w-30 is used for the 92 I-4 Camry right?
I had 2 different brands I used in the oil change tonight. I used Castrol advanced miles and Wal-Mart regular 5w-30. Im 90% positive they were both 100% dino oil not synth. That shouldnt be a biggie right?
1992 Camry I-4 with 145K miles
Deadly Sushi is offline   Reply With Quote
Old 07-16-2009, 07:53 AM   #2 (permalink)
Gameroom cash: $304355
No, it's not a biggie, but I think the recommended oil for your car should be 10W-30. Check what's written on the top of the oil cap (if it's original) or read your owner's manual. The 5W-30 you used is no biggie either, just check the oil frequently because the engine will use a bit more oil with the thinner weight oil in there, especially this time of the year with warmer temperatures. Switch to 10W-30 on your next oil change.
Mike
Old 07-16-2009, 04:56 PM   #3 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
I agree, not a big deal. Even if one was synthetic and one was dino, you'd basically just be creating your own synthetic blend. I believe Mike is right about 10W-30 being called for but I actually use 10W-40 because of the warm climate and age of the motor. Still purrs like a kitten and is virtually silent at idle
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 07-17-2009, 09:04 AM   #4 (permalink)
View RandySolara's Photo Gallery
For old Camry Engine, use 10-30W , new VVT-i 3.3 3.5 i think 5-30W and later on 10-30W , for Toyota Engines use always with 5-30W.
Mike is correct, due to the hot weather, we use 10-30W for older engine 130k/m + about more than 120k miles
Camry 92 is ok for 10-30W, if u dont use Synth oil no need for Walmart, go to Bodyshop they cost cheaper including oil-filter.
RandySolara is offline   Reply With Quote
Old 07-28-2009, 01:46 AM   #5 (permalink)
OK!!! So for a 1992 with 142K miles..... I should use 10w-30? Not 5w-30?
Old 07-28-2009, 08:17 AM   #6 (permalink)
Correct.
Mike
Old 07-30-2009, 07:53 PM   #7 (permalink)
UWAdventurer's Avatar
View UWAdventurer's Photo Gallery
Should be no big deal. I've done the same in my vehicles from time to time trying to finish up partial bottles of oil. No ill effects, I use full synthetic and change my oil every 5000 miles. I've used Amsoil, Mobil1, Castrol, Pennzoil, Quaker State, Supertech, just about all of them, from 10w-30 thru 5w-50 in my Dodge Dakota 4x4. I've used Amsoiil, Mobil1, Purolater, STP and Supertech oil filters.
FYI all, the 2010 Camry LE 2.5 L 4 cylinder uses 0W-20. Trying to boost EPA GPM ratings I assume.
Razzi Ground effects kit & simulated dual exhaust, factory spoiler, 20% hybrid tint, Wade window vent visors, fog lights, chrome lower grill accents, Kleen wheels, K&N filter
UWAdventurer is offline   Reply With Quote
