Noisy Steering Wheel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-10-2004, 02:50 PM   #1 (permalink)
View chitowncamry's Photo Gallery
Unhappy Noisy Steering Wheel
When I start out in the morning and turn my steeriing wheel it makes a high pitched sound real briefly. Any ideas on what that could be?
thanks
chitowncamry is offline   Reply With Quote
Old 02-10-2004, 03:49 PM   #2 (permalink)
View acecl22's Photo Gallery
yeah, my 91 camry does this too, actually, when its cold, right when i start it up not just the steering wheel squeaks, but the engine itself squeaks until its warm
acecl22 is offline   Reply With Quote
Old 02-11-2004, 08:16 AM   #3 (permalink)
3rd 5-speed Camry...
87Camry5Speed's Avatar
View 87Camry5Speed's Photo Gallery
Re: Noisy Steering Wheel
thanks
Are you talking about the wheel itself or the whole steering system?
My guess would be the power steering pump is low on fluid, give it a look.
However, seeing as you're from Chicago, I'd guess the cold weather has something to do with all the racket. You probably also noticed that in extreme cold your P/S is pretty heavy when you get going, as the fluid gets warmer and thinner you dont need as much effort.
I notcie that if you keep the car moving, even if only a little bit, when turning the wheel it's a little less stressful on the pump.
acecl22 that squeaking might be a loose accessory belt, so you might want to look there. At least that's been the problem in my experiences.
Steve
'08 Camry LE 5-speed. Traded for an '04 Mustang GT.
87Camry5Speed is offline   Reply With Quote
Old 02-11-2004, 10:35 AM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $397060
iTrader Score: 13 reviews
it's probably the steering column.....take a look at all the joints/moving parts on it, grease it up, and you'll be fine.....take a look at where the wheel meets the column, and also where the column meets the firewall
HaHa
Old 02-20-2004, 07:51 AM   #5 (permalink)
View haa21's Photo Gallery
Did anyone find a sloution to this problem? I have the same problem on my 2000 Camry LE-V6. I checked my fluid and it was at a proper level. I did top it off. I lubricated the steering column both indise the car and behind the firewall. I still notice I get noise. I check the hoses (as best I could see without gettingunder the car) and I don't see any signs of leakage.
haa21 is offline   Reply With Quote
