Engine can't start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-24-2009, 07:28 PM   #1 (permalink)
View tommytang's Photo Gallery
Question Engine can't start
I have a 97 Camery LE. Today I found I couln't start the engine. When I turned the key to start engine, I heard sound "Ta ta..." and found the the left most LED (a small car with some flash in the front) on dash board was on. I tried radio and the headlight, all was OK. But I found the time on the radio is not correct. Yesterday everything was normal. Is it because of low battery or some electric circuit problem? Thanks!
Tommy
tommytang is offline   Reply With Quote
Old 07-24-2009, 07:32 PM   #2 (permalink)
2004 Camry LE
somick's Avatar
Gameroom cash: $102015
View somick's Photo Gallery
I would blame the battery.
Try to jump start the car, go to Autozone or any other automotive store and ask them to check out your battery/charging system.
Good luck,
Sam
2004 Toyota Camry LE
1999 Honda Accord LX
1992 Subaru Loyale
2010 Subaru Forester
somick is offline   Reply With Quote
Old 07-24-2009, 08:12 PM   #3 (permalink)
Thanks, Sam. I hope it is the problem of battery so that all I need to do is to change a new battery.
Old 07-24-2009, 08:48 PM   #4 (permalink)
One of my friends told me that if all the electric accessaries such as light, windshield wiper work normally, it is not the battery problem. It might be starter's problem. All my electric accessaries work fine, so what should I do?
Old 07-25-2009, 07:05 AM   #5 (permalink)
Gameroom cash: $304355
Are you hearing 1 click or multiple rapid clicks when you try to start the car? It makes a difference. Also how many miles are on the car? How old is the current battery?
Mike
Old 07-25-2009, 08:44 AM   #6 (permalink)
View JerryR's Photo Gallery
I "kind of" agree with Sam, this sounds like a battery problem but it's not necessarily a bad battery. You may have a bad(oxidised) connection at the battery terminals(very common). Disconnect the terminals clean them and the battery posts until they are shiney, reconnect and try to start. If it still does'nt work I would suspect the battery itself.
The reason the lights workand the starter does not, is that the lights are a much lighter load on the battery than the starter. The fact that you found the time on the radio to be off is because it lost power when you tried to start the car, my guess is that you also lost your radio preset stations.
HTH
JerryR
yjryba<at>yahoo<dot>com
To contact me via Email
Replace Text within< > with proper symbols.
JerryR is offline   Reply With Quote
