Domelight Supervision - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-12-2004, 04:50 PM   #1 (permalink)
GOT A 93CAMRY&92MR2-T?
Zer05's Avatar
View Zer05's Photo Gallery
Question Domelight Supervision
I have a clifford alarm and I was planning on adding the domelight supervision myself. All domelight supervision does is activates the domelight with a relay when you disarm/unlock the car. My questions is where can I find a reliable website with all the wiring diagrams for a 93 Camry. So far I found the wires I need to get the domelight supervision working except for one the domelight supervision wire which is the door pin wire. I'm not sure if thats the switch for the door to indicate whether the door is open or close. Or is it something else. Neep help.
05
Zer05 is offline   Reply With Quote
Old 02-12-2004, 05:04 PM   #2 (permalink)
sargdesigns
arcasmachineracing's Avatar
View arcasmachineracing's Photo Gallery
I was thinking this thread was about some sort of micro camera placed in your domelight to monitor your activitys, you know, so mom at home can watch your every move...
Brandon
arcasmachineracing is offline   Reply With Quote
Old 02-12-2004, 05:09 PM   #3 (permalink)
Zer05's Avatar
Talking
LOL..I guest the title of the thread sounds like something like that..lol..
05
Old 02-12-2004, 05:17 PM   #4 (permalink)
sargdesigns
Know anybody that works at a Alarm Shop? They could help you out no problem.
Brandon
Old 02-12-2004, 09:43 PM   #5 (permalink)
FloridaPino
eviltwin67's Avatar
View eviltwin67's Photo Gallery
Try www.caralarms.com. They sell the wiring diagrams for installing alarms yourself for $3.99.
96 V6
Amsoil foam filter
Upgraded headlight Harness w/ Sylvania Cool Blue
APS 996A Remote Start Alarm
eviltwin67 is offline   Reply With Quote
Old 02-12-2004, 11:57 PM   #6 (permalink)
club momentum moves you !
shook's Avatar
View shook's Photo Gallery
if i remember right the door trigger wire is red\white and can be found in the driver kick panel.. its a negative trigger. i dont know the wire colors for a clifford alarm but some alarms will already have a domelight supervision wire and most are defaulted negative so that means you can just tap that wire into the doorpin wire. if the domelight supervision wire from the alarm is positive youll need a relay, run a wire from terminal 30 (common) on the relay to the door.. terminal 85 (coil) to the postive domelight supervision wire from the alarm.. terminal 86 (coil) and 87 (normally open) to ground and 87a (normally closed) is left empty.
-shook
shook is offline   Reply With Quote
Old 02-13-2004, 12:04 AM   #7 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: Domelight Supervision
"Skoolin' the unlearned!"
Old 02-13-2004, 12:12 AM   #8 (permalink)
shook's Avatar
oooo gotta love techsoft
-shook
Old 02-13-2004, 03:01 PM   #9 (permalink)
Zer05's Avatar
Thumbs up Right on!
Thanks for the help you all. Now I can finish my installation just needed to make sure a was using the right wires. Let there be light when I disarm/unlock my alarm lol..
05
