2006 Camry electrical?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-03-2009, 07:52 PM   #1 (permalink)
View jstib1's Photo Gallery
Exclamation 2006 Camry electrical??
Help! Just today the rear brake lights on my 2006 Camry (63,000 miles) won't turn off, even with the car in park, car turned off and key removed! This same day, the cruise control no longer works, even though the dashboard indicates it is on. Any help would be greatly appreciated!
jstib1 is offline   Reply With Quote
Old 08-04-2009, 09:02 AM   #2 (permalink)
Gameroom cash: $304355
Check the brake light switch and it's wiring at the brake pedal. Both those symptoms would indicate to me that it is stuck in the on position. The switch should be attached to the brake pedal assembly.
Mike
Old 08-04-2009, 07:06 PM   #3 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
^ Good diagnosis. If the car thinks you're pressing the brakes, that explains why your CRUISE indicator is on but your cruise control does not engage.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
