I stripped one of the strut nuts when I tighten it.. what should I do? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-13-2004, 06:05 PM   #1 (permalink)
View Protocold's Photo Gallery
There are 3 strut nuts on each side of the front assembly.
When I try to tighten one of them after I put new strut in... i stripped one, it now keep turning whenever I try to either losen it or tighten it..
what should I do?
Protocold is offline   Reply With Quote
Old 02-13-2004, 06:25 PM   #2 (permalink)
Prepare tortilla chips.
Daffunda's Avatar
View Daffunda's Photo Gallery
get a new nut.
man, you shouldn't be doing this unless you have a torque wrench and the torque specs.
Daffunda is offline   Reply With Quote
Old 02-13-2004, 06:59 PM   #3 (permalink)
ya i have a torque ranch and a torque spec.. but just that i still hear that groaning noise on my gen4 so i thought i might have to tighten it some more...
now i need to figure out if i have damaged the bolt thread or it just the the nuts get messed up..
Old 02-13-2004, 07:11 PM   #4 (permalink)
yah ..... okay
View Neon's Photo Gallery
i believe the noise is because of faulty strut mount, not the nuts, you should get the nut replace asap =)
*Image removed. Too big. You know the rules!* -Phi
Neon is offline   Reply With Quote
Old 02-13-2004, 07:25 PM   #5 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
back the nut out, if it won't go, then wedge a flathead screwdriver under the nut and pry it up while backing it out
-Nick
Nick is offline   Reply With Quote
Old 02-14-2004, 01:51 PM   #6 (permalink)
View rocky7's Photo Gallery
Get a new strut mount, then use a nut spliter and broke the nut off. The threads on the mount are stripped not worth running a thread chaser throung it because of the safety factor involved. Better to be safe in this area.
rocky7 is offline   Reply With Quote
Old 02-15-2004, 10:26 PM   #7 (permalink)
Actually the bolt is long enough that after my nut went in and stripped, I still have some thread left that I can put another nut on top.... is it good idea to do so?
Old 02-17-2004, 07:32 AM   #8 (permalink)
View tightcamry129's Photo Gallery
good luck trying to find the right size for those studs... I'm in the same boat as you are with the stripping of the stud and the nut. I actually found a really good deal on ebay for the new left and right strut mounts/plates so i went ahead a bought it.
tightcamry129 is offline   Reply With Quote
Old 02-17-2004, 02:18 PM   #9 (permalink)
oh i went to junkyard today and find a right nut from another camry and stick it in on top of the stripped nut.. looks like it is going to fix it for now..
any comment?
Old 02-17-2004, 02:20 PM   #10 (permalink)
Nick's Avatar
did you get the stripped nut off? if the stud is fine, then just toss another nut on there
-Nick
Old 02-17-2004, 10:43 PM   #11 (permalink)
I cant get the stripped nut off without breaking anything...
I think both the nut and the thread are gone :<
that is why I just put that nut right on top.
