Car won't start! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-13-2004, 08:31 PM   #1 (permalink)
View joemomma's Photo Gallery
Car won't start!
I've been doing some work on my 94 4cyl, and now it won't start. The weird thing, is that I haven't done anything to the electrical system. I have replaced the down pipe, the fuel filter, PCV valve, front rotors and pads, and changed the oil. A few weeks ago I replaced the negative battery wire, but I have started it a couple of times since then.
The battery has been tested and is fine, so I took out the starter and had it checked down at autozone, and they said it was bad, so I got a new one and the car still won't start. When I turn the key, I hear two clicks, one sounds like it is from the starter relay, and the other one sounds like it is from the ABS actuator. I have just about run out of ideas, so any help would be great. Thanks.
joemomma is offline   Reply With Quote
Old 02-13-2004, 09:16 PM   #2 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
If you changed the negative battery cable then check the ground connections on the chassis. There may be a poor surface contact or loose wire connections. What gage wire did you replace it with?
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 02-13-2004, 09:41 PM   #3 (permalink)
I reconnected the ground, but I will definately check it again. All the lights etc. work, so wouldn't that mean that the connections are o.k? I replaced it with 6 gauge wire.
Old 02-13-2004, 11:55 PM   #4 (permalink)
Group Buy Junkie
View jhale1's Photo Gallery
My '93 has trouble with the "neutral safety switch". Even with the shifter in park, it doesn't acutally know it and I have to put it in neutral to start the car. You might try that.... I don't know if the '96 is the same, but on the '93 there is a button next to the shifter (underneath a cover you have to pry off) that will allow you to shift without the car started.
jhale1 is offline   Reply With Quote
Old 02-14-2004, 05:08 AM   #5 (permalink)
View Nico's Photo Gallery
Might seem dumb but since you changed the fuel filter are you sure gas is still coming ? From my experience problems you get are often coming from something you've just done...
Nico
Nico is offline   Reply With Quote
Old 02-14-2004, 09:23 AM   #6 (permalink)
Thanks for the suggestions, I will try it in neutral. As far as the fuel filter, I am pretty sure that I did it right, but even if there was a problem there, the starter should still turn, shouldn't it? Does anyone know how to tell if the relay is bad?
