short in my brake wires? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-14-2004, 11:37 PM   #1 (permalink)
Oomp loompa doopidy doo..
spills1969's Avatar
View spills1969's Photo Gallery
I dont know wtf it is, but whenever I hit my brakes, its like everything on my dash kinda flashes, "door" light mainly. is this a short somewhere, or is it a possibility that my alternators goin out? I know I can get it checked out at my work, but i usually forget about it. How bout it, any takers on this?
http://www.cardomain.com/id/manwhorecamry
Nitrous is like a hot woman with STDs. You wanna hit it, but you're scared of the consequences...
spills1969 is offline   Reply With Quote
Old 02-15-2004, 02:33 PM   #2 (permalink)
ubongen's Avatar
View ubongen's Photo Gallery
I have the same problem. when I depress my brake pedal...my insturment cluster, my headlights....flicker. I think it's a loose ground wire. Although..it's been about over a month that it hasn't happened. weird. I musta hit like some bump and it musta fixed the loose ground.
my suggestion.... get a continuity tester...and check the wiring around your instrument cluster and door switch. I regrounded my door switch by sanding down the contact patch of it a bit more so that there's more of an exposed area for contact. Whatever I did.. I got lucky and the flickering went away.
good luck... Paul
'89 Camry DX bonestock w/168k with lots of future mods to come.
ubongen is offline   Reply With Quote
Old 02-15-2004, 06:57 PM   #3 (permalink)
N/A bites
Tercel GTS's Avatar
Get somebody to watch your brake lights when having those kinds of problems. Burnt ground connections in late model tail light systems are very common today with the use of plastic and higher powered bulbs together. You may also consider removing the tail lights and do a thorough inspection for melted ares around the bulbs and their ground connections.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 02-15-2004, 07:19 PM   #4 (permalink)
camry Wookie
View gaak's Photo Gallery
maybe your car is posessed.....
gaak is offline   Reply With Quote
Old 02-15-2004, 10:30 PM   #5 (permalink)
spills1969's Avatar
At least it wud have more life to it. Right now its a dieing hunk of metal.
