hmm here goes again camry help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2004, 12:52 AM   #1 (permalink)
kb8
View kb8's Photo Gallery
hmm here
I got a problem with my 91 camry, everything starts up fine, but sometime when i start driving the car, it will choke and stall when i press on the gas, if i released the gas pedal when it choke, it will be fine, but at the end it will always stall. This happen especially after rain or in winter (but it extreme cold it will be fine)
But if i start the car and let it idle for 30 min before going, everything will be fine, havent have any stalling if i idle it first for 30 min.
But this takes so much time, anyone can help?
kb8 is offline   Reply With Quote
Old 02-19-2004, 01:01 AM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
check your distributor cap, ignition wires and coil, there's probably something cracked in there
-Nick
Nick is offline   Reply With Quote
Old 02-19-2004, 01:10 AM   #3 (permalink)
S14 Fever :D
Rapeacivic's Avatar
View Rapeacivic's Photo Gallery
Also check your o2 sensor. I had a stalling problem with my car a while back and it turned out to be my o2 sensor. Got it replaced and my car hasn't stalled since. Not saying that thats your problem. I would make sure to check everything Oldman told you to check cause he has a lot more experiance working on engines then I do.
Originally Posted by LynchburgCSI View Post
Ladies and gentlemen... the only turbo 5s-fe camry still in existence. Welcome back Terry. I can't wait to see how this goes.
Rapeacivic is offline   Reply With Quote
Old 02-19-2004, 01:26 AM   #4 (permalink)
kb8
ok ill try to check on those at a garage
forgot to say, i change the engine oil 3-4 months ago and the stalling problem seems to stop right after the changing oil, but then after 1 week everything came back stalling again.
thanks
Old 02-19-2004, 03:01 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Cracked coil.
Its a common problem on gen 2 Camry's and causes the problems that you listed.
"Skoolin' the unlearned!"
