PATIENCE PLEASE, LONG POST
Originally posted by Silver Streak
....my alternator is dying....Headlights and my stereo ........were on. My indiglos flickered too! And when I brake, my indiglos flicker...maybe I have a bad ground... I had fogs, 2 amps, stereo, wipers on....
ALL that were ON!!
If you add up the current draw for all these devices, they may be more than what your system is able to sustain, especially at a stop light, and in gear.
The alternator needs the power from the engine to drive this, but at idle and in gear, the torque converter robs a fair chunk!!
Here are some ball park estimates
rear window defogger 15
Head Lights 10 (conservative) amps
Fogs, another 10 (conservative) amps
Brake Lights 5 amps
Other accesories 10
Stereo 15 amps (an estimate too)
Wipers 10 amps
If I recall the Alternator when new gives about 65 to 70 amps
That is about 75 amps there, and your battery wants some for charge as well
Better grounding is a solution. The Weather, like today, it really is tough on the car.
Try gounding upgrade first (I am in the process of making a set for myself) it is cheapest. An estimate of 20 dollars in parts.
Another battery, or a higher output altenator may be needed in your case with your amplifiers.
Oh yeah,
If you have higher watt headlights, try:
X watts/14volts to get amps.
Then do a good battery check, if you take it out, and give it to Canadian Tire it is free, you supply labour and transportation cost.
A larger battery may be all that you need, and not a second one.
