swapping gauge faces - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-21-2004, 03:58 PM   #1 (permalink)
ubongen's Avatar
View ubongen's Photo Gallery
question:
when swapping out the old gauge faces for a new one... how did you guys remove the needle that points out the MPH and RPM..?
those things are a pain to pull out and I think I threw off the calibration of my spedometer. now I think it goes 10mph too fast. any other suggestions on pullin' them things out?
thanx...
-Paul
1992 Tercel DX
pretty much bonestock w/100k
and right now I'm wondering
if I really get 37+ mpg.
ubongen is offline   Reply With Quote
Old 02-21-2004, 06:46 PM   #2 (permalink)
View Jettdawg's Photo Gallery
are you doing white guage faces? if you are then there is no need to remove them i think
Jettdawg is offline   Reply With Quote
Old 02-21-2004, 07:17 PM   #3 (permalink)
The Rent is Too Damn High
Deuce's Avatar
View Deuce's Photo Gallery
if you're just using the "slip cover" kind (the ones that don't have mechanical parts attached), you just slip the needles through the center holes.
I don't need a sig, I'm 31.
Deuce is offline   Reply With Quote
Old 02-22-2004, 08:54 PM   #4 (permalink)
View warlock's Photo Gallery
i removed mine inorder to put my indiglos on but what i did was
start up the car and get it to full temp,and idel plug the rpm needle on,then get to a open road and berly let the car move
then put the needle on the speedo at 0 ,you will be off a little put not a lot right now i'm 4 miles over at all times works for me
warlock is offline   Reply With Quote
