Shifter assembly modification details - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2004, 10:06 AM   #1 (permalink)
View Meisner's Photo Gallery
I'm modifying a gen4 shifter assembly to allow the use of a TRD quickshifter in my gen3 tranny swap. Someone had pictures on how to modify the gen4 shifter and now I can't find them.
Anyone know where these are???
1996 Turbocharged Camry 5S-FE (4 cyl)
http://www.meisners.net/camry
Meisner is offline   Reply With Quote
Old 02-22-2004, 07:33 PM   #2 (permalink)
camry Wookie
View gaak's Photo Gallery
i think with the '96 shifter assemble u can use the stock gen 3 assembly with modifications for the trd short throw shifter, but i'm not totally sure. Does your shifter have the plastic assemble with bolts that hold it down into the metal? the other configuration involves threaded studs coming up into the shifter assembly with bolts from the top...and for that i think you need the gen 4 assembly, but let me know and i'll see what i can do to help.
gaak is offline   Reply With Quote
Old 02-22-2004, 07:54 PM   #3 (permalink)
OK, this is gen3 shifter assembly I have:
This is the gen4 assembly I was going to use for the TRD quickshifter:
I tried the TRD shaft in the gen3 assembly and it seems to fit. The lower cable attachment at the bottom of the shaft does come down quite far...but it does with the gen4 assembly as well.
Thanks for any tips!!!!!
Steve
Old 02-22-2004, 08:20 PM   #4 (permalink)
camry Wookie
ok, here's what i did. on the gen three assembly i seperated the plastic section from the metal lower section. then I used longer bolts and a few nuts that were too big as spacers on the corners to extend the length that u have for the bottom of the shifter. then all you do is put in the TRD nob and re install it. if you choose to use the gen 4 set up, just mount the lever in the assembly and mount the assemble in the car.. that simple, just make sure everything moves properly and make the neccesary adjustments.
Old 02-22-2004, 08:26 PM   #5 (permalink)
Excellent! Thanks for the feedback & tips.
I like how the gen3 shifter assembly puts the shifter closer to the stock spot than the gen4 assembly. So I think I'll mod the gen3 assembly as you pointed out.
Anyone need a gen4 assembly all ready modified to fit in a gen3???
Thanks again!
Steve
Old 02-23-2004, 02:16 AM   #6 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
yes! i need!!! NOW!!! you have it complete right?? cause in that pic the ball of the shifter was exposed... talk to me on AIM tomorrow
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 02-23-2004, 02:19 AM   #7 (permalink)
camry Wookie
i feel so special! i helped TWO people now with one thing....niiiiice
Old 07-23-2004, 07:06 AM   #8 (permalink)
CTM/ShiftGate CAMRY
racerhex's Avatar
View racerhex's Photo Gallery
so im not sure I understand does the gen 4 assembly fix the problems with the gen 3 hidth? Because my TWN shifter is rubbing the bottom of the body of the car causing just a bit of shifter stifness. I want the assem to come up higher and does or dosnt the gen 4 do that? Thankss
3vz-fe w/ all the good stuff
Does My Wiper Offend You? Look Ma no handles!
www.ctmotorsport.com FOR ALL YOUR CAMRY NEEDS
http://members.cardomain.com/racerhex<----CHECK ME OUT...UPDATED!!!!
racerhex is offline   Reply With Quote
Old 07-23-2004, 07:15 AM   #9 (permalink)
Yes, it does. That's why I started out with the Gen 4 shifter assembly to use in a 3rd gen. I was trying to use the TRD quick shifter for the gen 4. So your TWN shifter would also work. The shifter sits up a little higher in the gen 4.
Old 07-23-2004, 08:24 AM   #10 (permalink)
CTM/ShiftGate CAMRY
racerhex's Avatar
thanks so much any idea why car-parts.com dosnt list shifter assems I need to find one???
Old 07-23-2004, 08:31 AM   #11 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ Get some longer bolts and shim the bish up with some washers. Its ghetto, but hey it might work.
Have you tried TAP Recycling (www.taprecycling.com) or a local junkyard for the shifter?
"Skoolin' the unlearned!"
