No Start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2004, 12:43 PM   #1 (permalink)
View bricksb's Photo Gallery
Unhappy No Start
I have a 94 Camry and out of the blue, coming out from shopping the shopping mall, started the car, put it in reverse and died. The starter cranks the engine but does not want to ignite. Had it towed home and I checked all the fuses, distributor cap, rotor, plugs and of course the battery - all checked good. I had the alternator tested and that checked good too. I checked the spark plug cables one by one and cranked the engine but no spark. Is there an easy way of tracing power to the distributor? Any possible cause that you can recommend will be appreciated.
bricksb is offline   Reply With Quote
Old 02-22-2004, 01:31 PM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
unplug the wire from the coil, see if you got spark there, if not it could be the coil or the igniter
-Nick
Nick is offline   Reply With Quote
Old 02-22-2004, 11:45 PM   #3 (permalink)
Smile NO START FIXED
After doing ohm readings on the internal coil, secondary contact kept showing "open". Replaced coil and car came back to life. Thanks for the help Oldman.
Old 02-23-2004, 01:11 AM   #4 (permalink)
Nick's Avatar
good stuff!!
-Nick
Old 02-28-2004, 02:29 PM   #5 (permalink)
View sleeping_minds's Photo Gallery
nice... i think thats what i need to do, but there are no camry's around here at all!!
if anyone knows a place where i can pick up a coil for a 93 3vz-fe
PM ME! thanks..
93 3vz-fe
only tuned camry around here
sleeping_minds is offline   Reply With Quote
