find an empty road, accelerate to 70mph ish, and apply heavy braking for a couple seconds, do this a couple times and they shoudl be deglazed
you can also get some anti squeek stuff at autozone or pepboys or whatever, i've seen it around, but i've never used it
edit:
when does it squeak? when you're driving at low speeds with very little brake on? if so then its your wear indicator on the pad
how much of the pad is left? you can also try roughing up the brake pads a bit with sandpaper, you might be able to get them to seat better (use a block of wood behind the paper so its a flat sanding surface)
-Nick
