brake switch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2004, 08:44 AM   #1 (permalink)
View calvic's Photo Gallery
brake switch
Anyone changed a brake light switch on a first gen. Camry (88)
I got no brake lights, checked fuses, grounds still no joy. Going to check brake switch but could see it as far as I could stick my head under the dash. ANy help?
JJ
calvic is offline   Reply With Quote
Old 02-23-2004, 01:58 PM   #2 (permalink)
Well checked brake switch, it good. Got voltage to the switch- got no voltage at brake lights. Suspect broken wire. No voltage at hinge arm so trying to work my way back forward. Hot wire is red green in the trunk and at the switch. I have the harness broke open at the rear seat down by the floor and guess what --No red-green wire. Anyone have a schematic and can see if wires change colors or what.
JJ
Old 03-09-2004, 11:30 AM   #3 (permalink)
Ok, figured this sucker out. Easest way to t/s no brake lights is to pull connector from light failure sensor (in left side trunk) check power from brake switch, then check continuity to brake lights from same connector. I had bad light failure sensor. Toyota wants $175 for this little jewel. I opened mine up and it had a broken solder trace. Soldered in a 22ga. jumper wire across he break. Go to go. I love brake lights!
JJ
