16" steel wheels question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-08-2009, 08:52 AM   #1 (permalink)
2010 Camry LE
View No Jeep's Photo Gallery
I would like to get 4 16" steel wheels that would fit my 2010 Camry.
I have only checked one scrape yard so far, but the guy there said I might have to buy new from Toyota, because these 16" wheels are new this year to Camry.
Are there any other 16" steel wheels out there that would work on my 2010 Camry.
I want to mount snow tires on them, and avoid having to go every spring and fall, to the tire shop to swap out the tires.
No Jeep is offline   Reply With Quote
Old 10-08-2009, 09:46 AM   #2 (permalink)
Camry Freak
98CamryLE's Avatar
View 98CamryLE's Photo Gallery
The steel wheels from 2007-2009 models should fit just fine, as all 07-2010 Camrys are equipped with 215/60R16 tires. (SE models are the only exception, as they come with 17" tires standard)
What you have to keep in mind is that unless you purchase and program additional wheel sensors, the tire pressure monitoring system will turn on when you switch to the new wheels.
2007 Camry Hybrid
98CamryLE is offline   Reply With Quote
