hissing from front wheels - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-26-2004, 06:43 PM   #1 (permalink)
View ausdag's Photo Gallery
My 95 camry seems to be falling apart. Now, when I drive I hear a noise like a steam train hissing as the wheels rotate. The fatser I go, the faster the 'steam train' effect. Any ideas? Thanks.
ausdag is offline   Reply With Quote
Old 02-26-2004, 07:30 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
Does it change when you apply the brakes?
雄のハヤブサ
Tercel GTS is online now   Reply With Quote
Old 02-26-2004, 10:01 PM   #3 (permalink)
no, it just gets slower as the wheels turn slower, like a steam train slowing down.
Old 02-26-2004, 10:02 PM   #4 (permalink)
Gameroom cash: $199835
View swegyptian's Photo Gallery
your brake caliper might be stuck. check (carefully by hand) if one front wheel is hotter than the other.
www.swegyptian.com
swegyptian is offline   Reply With Quote
Old 02-27-2004, 06:38 PM   #5 (permalink)
N/A bites
Tercel GTS's Avatar
jack up the car and in nuetral by hand turn each wheel to determine which is causing the problem. Once you determine this remove the wheel then take the brake caliper off the mount and tie it to the side out of the way. Bolt the wheel back on and spin it again. If you still have the noise look into the wheel bearings as the source. Do not let anybody step on the brake pedal while the caliper is off!
雄のハヤブサ
