sounds like howling spirit.mp3 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-27-2004, 04:18 AM   #1 (permalink)
Judo photoCHOP!
View amphipri0n's Photo Gallery
Question sounds like howling spirit.mp3
So, I've racked up about 19,800 miles on the car as well as the tires which it came with(215/R16 Toyo Proxes J33) and have started noticing a low howl/hum at around 70mph. Pretty sure the noise isn't from the engine since it's not there when running similar RPMs at lower speeds...
I checked the tires and they have 1/8th of an inch left of tread. The tires are high performance summer tires, but I've been running with them in cold, wet weather for the last 4 months and no problems till now. Treadwear is a meager 200, but still-- doesn't that mean it should be good for up to approx. 60k miles??
Any info/suggestions are appreciated.
Gen5 Camry SE
amphipri0n is offline   Reply With Quote
Old 02-27-2004, 06:33 AM   #2 (permalink)
View Nico's Photo Gallery
Hav you had hem balanced ?
Nico
Nico is offline   Reply With Quote
Old 02-27-2004, 08:57 AM   #3 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
if you drive real agressive, especially with 200 thread wear, you'll go through them real quick
-Nick
Nick is offline   Reply With Quote
Old 02-27-2004, 12:46 PM   #4 (permalink)
slowamatic noob
a94autoCamry's Avatar
Gameroom cash: $149910
View a94autoCamry's Photo Gallery
Nirvana - Smells Like TEEN Spirit.mp3
slow white - "no show and no go"
a94autoCamry is offline   Reply With Quote
Old 02-27-2004, 03:39 PM   #5 (permalink)
Boondock Saint
View 89SV21's Photo Gallery
usually 200 tread wear tires are only good for 20-30K. they're so soft that even if you moderately flog your car on the mountain twisties you'll kill the tires in no time. also make sure that your alignment is ok cause if your camber or toe is messed up your tires will die ever quicker.
"Fur pie doesn't sell"
89SV21 is offline   Reply With Quote
