Red radiator fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-27-2004, 07:38 AM   #1 (permalink)
View oldmanriver's Photo Gallery
Red radiator fluid
We have a 1998 Camry with a 4 cyl engine that just began to get a "hot" smell after running for a while. I popped the hood last night, removed the radiator cap and discovered that the coolant is red. I assume that this means transmission fluid is mixing with the coolant. I didn't get a chance to look at it further, but is there a seperate cooler for the trans fluid? Or does it run inside the radiator? What is involved in taking care of this problem?
Thanks in advance.
oldmanriver is offline   Reply With Quote
Old 02-27-2004, 07:53 AM   #2 (permalink)
View crazy_camry's Photo Gallery
i think the toyota coolant is red, and from what i've heard, some of the best out there
crazy_camry is offline   Reply With Quote
Old 02-27-2004, 08:06 AM   #3 (permalink)
View haa21's Photo Gallery
I have a 2000 Camry and the coolant is red. It is 100,000 mile coolant.
haa21 is offline   Reply With Quote
Old 02-27-2004, 08:36 AM   #4 (permalink)
3rd 5-speed Camry...
87Camry5Speed's Avatar
View 87Camry5Speed's Photo Gallery
Coolant should be red (unlike mine but that'll change next weekend ), it's nearly impossible for ATF to mix with antifreeze as the two systems (cooling/trans) have nothing to do with each other
Steve
'08 Camry LE 5-speed. Traded for an '04 Mustang GT.
87Camry5Speed is offline   Reply With Quote
Old 02-27-2004, 09:01 AM   #5 (permalink)
View Deep's Photo Gallery
Just a note, you should avoid mixing the OEM red Toyota coolant with the stuff from Prestone et al.
Deep is offline   Reply With Quote
Old 02-27-2004, 09:43 AM   #6 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112150
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
...next time please use the SEARCH button
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is online now   Reply With Quote
Old 02-27-2004, 03:34 PM   #7 (permalink)
Boondock Saint
View 89SV21's Photo Gallery
the deep's right, oem toyota coolant is 5yr coolant and prestone( the green stuff) is one year coolant. if ya mix em even at all the majestic 5 yr qualities of the oem coolant become null and void and it becomes plain old 1 yr coolant.
"Fur pie doesn't sell"
89SV21 is offline   Reply With Quote
Old 02-27-2004, 04:36 PM   #8 (permalink)
VVT-i Owns's Avatar
View VVT-i Owns's Photo Gallery
Yet Toyota Recommends changing it 36000KM or every 24 months
- Vince
VVT-i Owns is offline   Reply With Quote
Old 02-27-2004, 06:17 PM   #9 (permalink)
Ok, thanks guys, I can't believe I never noticed that the coolant was red before. I will check it out tomorrow and see where the heat is coming from.
Old 02-27-2004, 07:06 PM   #10 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: Red radiator fluid
The tranny cooler (auto tranny) is built into the radiator. If you look towards the bottom right side of the radiator you'll see 2 hoses that run to the tranny.
By the way Toyota coolant is red.
"Skoolin' the unlearned!"
Old 02-28-2004, 01:41 PM   #11 (permalink)
Well don't I feel stupid, the hot smell was a plastic shopping bag melting on the exhaust pipe underneath the car, it must have blown under and wrapped around it.
