odb codes (P0300, P0302, P0303, P0304) after changing battery
Hello,
Today, I replaced the battery on my 2000 Camry LE. Immediately after turning on the ignition, the engine started sputtering, RPM going up a little, then back down, then back up, etc...
Also the check-engine light was on, hence my checking the code(s). I found P0300, P0302, P0303, and P0304 . I reset these codes and now the engine appears to be running fine again.
Does this behavior make any sense to anybody? Beyond just keep monitoring it, I am not sure how to interpret this event.
Any words of wisdom would be appreciated.
Thanks.
