I guess I could. I have the main hoop drawn out on plywood. I made a template inside the car from 1/4" rod and bent it around one of my 13" brake discs
I made sure it would clear everything. The main hoop doesn't clear the rear door armrests though because it is just a little wide, but I replaced them with carbon panels anyways. (I had that one planned because I have no rear seat.)
This cage would still allow the rear seat to be put back in except for the side pop out bolsters that cover the suspension mounts. A person could trim the pieces and re-upholster them to fit.
I just downloaded autocad, so I can start drawing sometime soon.
Since those photos were taken I installed an X brace in the rear (this makes the rear seat area useless) and I am also cutting out the spare tire well, since it is just sheetmetal and kinda useless. Replacing it with 2x2" tubing and flat sheetmetal and recessing the battery box, so I have clearance for ground effects under there. I thought about a fuel cell, but the rules let you keep the original gas tank, which is low to the ground anyways.
