2004 Camry ATF change w/o filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2009, 08:37 AM   #1 (permalink)
View john6247's Photo Gallery
Hello,
Here is what I did: I pumped out and replaced 2 quarts of the ATF fluid using a hand pump and an ice maker plastic tubing inserted in the dip stick hole, and now I am losing my sleep over it . I needed to push the tubing deep into the dip stick hole and I am worried that I may have pierced the filter or damaged something else...please let me know what you think! I faled to mention it's a Camry 4 cylinder
Thanks
john6247 is offline   Reply With Quote
Old 11-15-2009, 09:26 AM   #2 (permalink)
View Axxis8203's Photo Gallery
i wouldn't say it's impossible that you damaged anything, but it is unlikely. and if you wanna stop losing sleep over this issue, your best bet it to just drop the pan and do a drain and fill which will allow you to visually inspect the filter.
by the way, why all the worrying, is the vehicle shifting funny?
also, if you only got 2 qts out then you didn't get much. as that tranny holds probably about 7-9 qts.
Wise Men STILL seek Him!
Axxis8203 is offline   Reply With Quote
Old 11-15-2009, 11:17 AM   #3 (permalink)
Gameroom cash: $202300
View zppeacock's Photo Gallery
But you will never get over 4 out of the tube, because the converter holds most of it
zppeacock is offline   Reply With Quote
