Originally Posted by muminiasty
Do you use torque wrenches only for tightening or you can loosen as well? Is loosening what do you adjust it to?
You should never really loosen bolts or nuts with a torque wrench. If the bolt/nut is seized you could damage the wrench calibration or worse.
In a very rough sense just think of a torque wrench as an adjustable spring with a metering device on the end. Take a spring out of a cheap pen and stretch it and you will get the idea.
edit: and again it depends on the type, a click style once it breaks (clicks) is just a pull bar (to a point) and a dial style just keeps loading up the pressure and is sensitive to overloading.
