Body Roll - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-28-2004, 08:12 PM   #1 (permalink)
Camryfanatic's Avatar
View Camryfanatic's Photo Gallery
Angry Body Roll
My friend tells me that my Gen. 3 Camry has tons of body roll. What can I do, to reduce it or get rid of it totally. Another question what is drag coeffiecent for my car?
Camryfanatic is offline   Reply With Quote
Old 02-28-2004, 08:20 PM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
basically spend a lot of money
sway bars and springs make the biggest difference,
stiff struts and a strut tower bar help too
if you're riding on original suspension, odds are your struts are pretty much done and your sway bar links are probably worn
-Nick
Nick is offline   Reply With Quote
Old 02-28-2004, 10:06 PM   #3 (permalink)
not actual size
brink's Avatar
View brink's Photo Gallery
^yah. The springs are what hold your car up, but give it the ability to not jar everything to hell when you hit a bump.
You've got to make a decision on how much ride comfort you're willing to sacrifice for stability, though. Stiffer suspension = stiffer ride.
-- Jonathan W.
http://fleshy.org.nz/
brink is offline   Reply With Quote
Old 02-29-2004, 08:30 PM   #4 (permalink)
If I added a strut tower bar, I would I see a difference?
Old 02-29-2004, 09:18 PM   #5 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112150
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
no. You need a rear sway bar. ...as well as springs and struts. You will see little to no effect from a front strut tower brace. The gen3 body is fairly rigid, its the weenie oem rsb thats giving you the trouble.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is online now   Reply With Quote
Old 02-29-2004, 10:42 PM   #6 (permalink)
Formula One Fanatic
andyman61's Avatar
View andyman61's Photo Gallery
Re: Body Roll
i'm a pretty big aero guy, so it would be interesting to see. anyone know off hand? if i had to take a blind guess, i would say like .34 or .35, but i have no idea.
Metal to burn, sparks to fly...
1992 Toyota Camry 5 Speed - 5S-FE....totally stock
andyman61 is offline   Reply With Quote
Old 03-01-2004, 08:48 PM   #7 (permalink)
Where is that piece on my camry?
Old 03-01-2004, 08:52 PM   #8 (permalink)
View soundlzrd's Photo Gallery
Its bolts to the lower part of your rear sturts. This helps keep the tires on the ground. Whiteline makes a bar for your car that runs 109. Check it out, www.ctmotorsport.com
soundlzrd is offline   Reply With Quote
