Originally Posted by judge34411
I imagine (and I do not know for sure) but your dealer should be able to reprogram your key/car (will actually be the car) so you can lock the car with it while the engine is running. But now the down side. If you mess up and lock that car with it running and no one inside..... well you get the complications.
An of course the new laws about leaving cars idle and such.....
Edit: probably right through the OBD
many thanks Judge for taking the time to answer my question...
What you mean by OBD? And if my wife can reach (although not easily) to find the driver side door lock switch, why on earth Toyota did not put another one for the front passenger like all decent cars. The car costs over 70 K USD and the switch would probably be less than 20 t0 50 bucks. Alternatively they can put the switch in the middle right under the Hazard signs switch, right?
Sorry about my ranting. I just found it annoying that little mistakes like these happens with good cars from good car makers!
Cheers for your answers anyways!
