Won't start when it rains - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-02-2004, 09:25 AM   #1 (permalink)
View cato47's Photo Gallery
Gentlemen, start your engines. New to the forum and hope someone can help with the problem. Have a 91 Camry 4 cyl that doesn't want to start when it rains and has sit for a day. Sometimes it flat won't start period, other times it will start but runs very rough until it warms up. I had this same problem with an 83 Toyota 4X4 wagon and the problem was moisture getting into the distributor cap. Has anyone had this problem and if so what is the cure. I haven't checked anything out yet and will wait to hear for any suggestions you may offer. Lastly, I don't know if the gasket between the distributor and cap is missing and if so, could this be the culprit?
Kindest regards in advance,
cato47@netzero.net
cato47 is offline   Reply With Quote
Old 03-02-2004, 10:51 AM   #2 (permalink)
View DIRTBIKEZ's Photo Gallery
Take a look at the ignition coil, its a a fairly common problem being that is is partly exposed so they can crack and allow moisture in.
'91 Camry DX
2.0L 3SFE Auto
R.I.P.
DIRTBIKEZ is offline   Reply With Quote
Old 03-02-2004, 11:13 AM   #3 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
distributor cap, ignition coil, and wires, check for cracks
-Nick
Nick is offline   Reply With Quote
