On 2002-03-27 12:40, HIP2HOP wrote:
hey...how much did it cost u to put that engine in...
I didn't do an engine swap, I just turbocharged the engine (3S-FE) that was already in there.
So now its a 3S-FTE. The "T" stands for turbocharged. :wink:
I've never really added up the cost of all the parts so i'll do it right now since you asked.
Turbo - $50 from a junkyard. I pulled it out of a 87 Saab 900 Turbo. It works fine, no shaft play, spins fine, and no oil leaks.
Turbo manifold - $75 from TAP Recycling. Its from a 91 MR2 Turbo. I live about 20 - 25 mins. away from them so I just picked it up.
BOV (blow off valve) - $163 ($138 + $25 shipping (came from Japan)) off of eBay. Its a Blitz Super Sound BOV (the older one with the big horn).
Earls fittings and stainless steel braided lines - About $175. I bought various fittings and lines for the oil feed, oil drain, and FMU.
Vortech FMU - My homie Steve had one that hes not using so he gave it to me for free. Their $140.55 from Vortech.
FMU recalibration kit - $52.53 from Vortech.
MSD 6A, MSD 8910 EIS tach adapter, MSD Blaster SS Coil, and MSD Super Conductor 8.5mm Coil Wire - About $240 from Summit Racing.
Autometer ATM-4301 Boost Guage - $53 from Tognotti's Auto World (big performance autoparts store here in town).
Exhaust flange and bung for 02 sensor - $10 from Muffler Tech.
Turbonetics manual boost controller, T3 turbine discharge weld flange, T3 oil drain adapter - $120 from Midnight Performance.
Various 2.5" OD mandrel bent pipes and ThermoTec header wrap - About $70 from Tognotti's Auto World.
Distributor cap + wire set, rotor, and 4 spark plugs - About $85 from a Toyota dealership.
Various brass fittings, steel rod, bolts, nuts, washers, hose clamps, and rubber hose couplers - About $30 from Home Depot.
Red high temp silicone, Bosch universal single wire 02 sensor, and 2 cans of high temp Dupli-Color engine paint - About $40.
I think thats about it for the parts. Theres alot of stuff so I might have forgot something.
The total comes to about $1200. That sounds about right. :smile:
I did all the work myself. I had to fabricate the pipes (make and weld) and make an adapter to go from the CT-26 style flange on the turbo manifold to a T3 style flange on the turbo. The good thing is that I saved a hell of alot of money by doing everything myself instead of paying a shop.
cuz im thinkin of doin and engine conversion for my 90' Camry
Be prepared to spend alot of money and time.
If your doing a 3S-GTE engine swap a complete US spec 3S-GTE with tranny will run you around $1200. JDM 3S-GTE's cost alot more. This is just the engine itself.
By the time your done with everything it'll be about $3500 - $4000.
If you want to build that 3S-GTE be prepared to spend atleast $10,000 for everything.
All the prices I listed are in USD.
