forgot the coolent
Turned on my car Camry 99 4cylinder. When it was in park the engine was reeving really high but putting it in drive seemed to fix it. I took a short trip, when I was headed pack I noticed the temp gauge was straight at the top. I immediately stopped and checked the coolant tank. Empty with steam coming out of the radiator. I typically only check the coolant every once in awhile so I don't know how long it had been empty. I filled it with coolent and drove around. The temp gauge was fine then shot up again then settled down and stayed that way. I lifted the hood again and the compartment was empty again but no leaks I could detect from the bottom, just some moisture around the radiator pipe at the very front of the car. I refilled it again hoping it would stay filled this time. If I can get the coolant level to remain steady. I was wondering if it is worth the risk driving it around as long as I stop regularly and check the coolant to refill. There doesn't seem to be any symptoms yet aside from what I just mentioned.
