90 camry trans a140e problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-25-2009, 04:34 PM   #1 (permalink)
castrator's Avatar
View castrator's Photo Gallery
USA 90 camry trans a140e problems
90 camry dlx 2.0 a140e "electric" shift trans. 246,000 miles.
problems = 1: engine warm reads low on dips stick wife drove 20 miles to town n back reread and it read almost 2 inches above "hot" , drained pan and refilled slowly making sure not to over fill ...read hot range at operating temp...read cold next morning it read 2inches above hot again???? (no clue how) ..drained again and filled to "hot range " transmission slips bad and will not go in gear till warms up...........so i put fluid in till it read almost 3inches over hot range (a gallon total) ...car will go in gear when cold now and shifts almost perfect when normal driving ....only thing now no kick down gear ...and flooring pedal in first gear it will shift straight to 3rd gear....and car sometimes dies coming to a stop which started when trans problems started. HELP ME PLEASE !!!!!! LOL
turned key forward and turned off o/d switch .........it stayed off meaning no codes stored in ecu.
never mind i need to jump a connector before looking for o/d flash codes sorry... will get back with this.
castrator is offline   Reply With Quote
Old 12-27-2009, 05:42 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
better post in the gen2 section.. but the tranny is very picky about the fluid level if you'r over/under .5qt it can cause shifting problem ... do a search on doctorj thread about it
